Eclatprime Digital Private Limited
SG
Posted: Jul 17, 2023
Last activity: Jul 3, 2024
Last activity: 3 Jul 2024 12:01 EDT
How to Connect AWS EFS to Pega application using YAML
Hi Team,
We are upgrading our application to Pega 8.8.2 and we want to use AWS EFS for the file storage.
We need help how to connect to AWS EFS from pega also while deploying the application using EKS what things need to be added in YAML file to mount the EFS to the EKS Cluster.
Pega YAML Side configuration is what i am looking so that i can update in yaml file and deploy the application.
@BhanuPrasanthT
this is solved by adding the mounting parameters with pv name sc class pvc and the folder to mount
