How to configure access for a connectSQL in producton
I have a connectSQL to update a database table and it's called by an activity. It works fine in development environment but when I deploy it production environment, it's not working and get error complains table does not exist. However when I check instances in Data-Admin-DB-Table, it's there as well as when I try to locate it via Schema tools.
Other things I noticed are:
1. Query inspector when evaluate query, the following error showed:
2. Query runner when run "select count(*) from theTable", I saw the following error:
There was a problem performing a database query: Database-General Problem encountered when getting connection for database pegadata 0 Cannot create PoolableConnectionFactory (FATAL: password authentication failed for user "ALCYON_RO")
DatabaseException caused by prior exception: java.sql.SQLException: Cannot create PoolableConnectionFactory (FATAL: password authentication failed for user "ALCYON_RO")
| SQL Code: 0 | SQL State: null
Can anyone explain the reason and how to configure to make the activity to call the connectSQL?
Thanks and regards
