How to change setting database from PegaData to external Database
Hi all,
We have setting for instance, when we tried to import our application, it made some change. Our instance need to load data from external database but when we check it moved to pr_other PegaDATA after import. Can we manually change it? or are we need to re-create the instance?
Dorkyark
Do you have a Database Table instance for that class? Did you move it and the external database instance to the new environment along with the class?
