Capgemini
How to capture Cookie information in Connect Rest response headers using POST method
I need to capture cookie value that is being sent in Connect Rest response headers.
When I hit the service using soap ui, I can see that response headers has "Set-Cookie" repeated 3 times as depicted in attached screenshot cookie.PNG.
Now in Pega when I am trying to map the "Set-Cookie" value to clipboard property, it is setting the last occurrence value whereas requirement is to capture the first occurrence value i.e. value starting with ObSSOCookie . Screenshot attached for Connect-Rest Post configuration i.e ConnectRest.PNG.
Any leads would be appreciated.
