Capgemini
Last activity: 13 Oct 2017 3:06 EDT
How to to Call a Function in HTML Fragment in an Activity
Hi ,
I am working with a BRE in Pega Proprietary information hidden Version , Currently there is a Java Code written in an Activity which in turn uses Java Class and Java methods in Java Step Method to Call external Jar file for Some Calculations .
Now there is a change coming up so that Jar file in Java is to be replaced with Java Script . The entire methods and calculations are put into JavaScript Function . As HTML or HTML Fragement is correct in Pega Proprietary information hidden .
is it possible to Call a Java Script function present HTML Fragment from an Activity ?if yes ,please could you help with the idea ?
thanks
dasaradha
***Edited by moderator, Maryrita: moved to Product Support from Pega Academy***
