How to avoid reading pzpvstream?
hi,
In a project of 8.5.1 I have defined a number of data types and configured their local data sources as tables in the PegaDATA schema. I noted that all the properties I included in configuring the data source are exposed as columns in the underlying tables. However, all the access to the records of the data type, either via data page or activities, are still reading the pzpvstream despite the fact that all properties are already exposed columns. While this is functioning, it is causing poor performance. Is there a way to suppress the reading of pzpvstream in the sql generated for data type without the need of deleting the pzpvstream column and restarting the whole system?
