Capgemini
NO
Last activity: 24 Jul 2020 10:59 EDT
How to access SMA in Pega 8.1?
It is not under System>>Operations anymore.
Likes (1)
S MANOJ KUMAR REDDY -
Updated: 11 Jun 2020 12:50 EDT
SMA is removed from System-Operations in 8.1.
To SMA features from designer studio add "pxAdminStudio" in your Accessgroup under available Portals and then switch from Dev studio to Admin Studio to access the SMA features.
S MANOJ KUMAR REDDY
PL
The functionality of SMA since 7.4 Was moved to the DesignerStudio and from 8.1 is no longer available. Please go to Designer Studio -> System -> Operations and you will find the all functionality from SMA.
Lukasz
Capgemini
NO
Apart from Logs and Archive/Purge, there is no other option under Configure -> System -> Operations
What specifically are you looking for?
PL
Sorry, my mistake, this instruction came from the 7.4. And in 8.1 you need to switch to AdminStudio. Please take a look at the below screenshot:
Under AdminStudio you will find all those functions.
Lukasz
Bank Of America
S MANOJ KUMAR REDDY
Anthem, Inc., USA
Personal edition of Pega 8.1, all the links under Admin Stuidio-> Resources are diabeled except API.
Could you please let me know any resolution for the same.
You can also explore the ? > Pega API > System Management(REST API calls related to SMA)
Anthem, Inc., USA
Under Pega 8.1 personal edition, Admin Studio-> Resources. All the options are disabeled except except API.
How we can enable them.
Please find the attached screen shot for the same.
Hi Nilesh,
Can you login with admin credential and verify the scenario.
Thank You,
AlfaBank
RU
I'm working on stand alone application for SMA. You can check it here: https://github.com/mishankov/pega-infinity-sma
