Here Maps Api Implementation
I would like to implement HERE Maps in Pega Platform. I tried to add the html code in the link below to non-auto generated section. But the section does not display anything. The HTML code I used is working cause I tried it on html file.
https://developer.here.com/documentation/maps/topics/quick-start.html
Is there anything else to do in order to implement this Api ?
Edit: We have purchased license for HERE Maps. We would like to implement it using Javascript API provided by HERE Maps. I tried to add the sample code above into HTML rule and reference that rule in a section in order to display the map on user portal. However the map's itself is not being loaded. Does anyone have idea about how can this be implemented on Pega ?
Thanks.
