Vodafone Portugal
PT
Last activity: 18 Aug 2022 8:14 EDT
Guidelines to run repair for Cassandra DB
Our DBAs recommend running repairs in Cassandra using the tool Reaper: Easy Repair Management for Apache Cassandra (cassandra-reaper.io)
Here is the proposal:
Because allCassandra nodes on all your 4 clusters have a JMX listener only listening on localhost, the setup of this tool could be:
- cassandra-reaper.io/docs/usage/multi_dc_distributed/ with selection “Multiple Reaper instances with JMX access restricted to localhost” -> every node has one reaper process, which handles local repairs.
- When you however allow JMX to listen on the ADMIN or PROD interface, then the setup can be easier “Operating Multiple DCs with a Single Reaper” -> centralized reaper process, which operates repair on multiple nodes. However this can be a security-concern as the JMX listener will listen on an external IP address.
What we would like to know from you:
- Is there any PEGA guideline to run repairs in Cassandra?
- Can we go ahead with above proposal?
