Billennium India
Last activity: 23 Jun 2017 16:57 EDT
Getting an error while hitting Service SOAP URL exposed by PEGA - "java.lang.NoSuchMethodError: javax.wsdl.Part.getExtensibilityElements()Ljava/util/List;"
Hi ,
We are using PRPC 6.2 SP2 .
i have created a Service SOAP in PEGA to be consumed by our one of internal client. But I am getting below error while hitting Service WSDL URL. i tried hitting it with SOAP UI client as well as directly on browser.
Same Service is working fine in DEV region . But when i moved code in QA i am getting above error. This is the first SOAP service which is created but not working in QA region. Other Service like MQ , and HTTP is working fine.
Can someone suggest something . Why this issue is coming in QA . but same worked in DEV . Anything Enviornment specific setting missed here?
Detailed Logs:
Hi ,
Detailed Logs:
2016-11-14 07:57:37,879 [http-bio-8383-exec-8] [ STANDARD] [ ] ( web.impl.WebStandardImpl) ERROR - xx.xx.xx.xx: Unhandled error in ETier invocation
at com.pega.wsdl.xml.WSDLWriterImpl.printParts(WSDLWriterImpl.java:761)
at com.pega.wsdl.xml.WSDLWriterImpl.printMessages(WSDLWriterImpl.java:716)
at com.pega.wsdl.xml.WSDLWriterImpl.printDefinition(WSDLWriterImpl.java:137)
at com.pega.wsdl.xml.WSDLWriterImpl.writeWSDL(WSDLWriterImpl.java:1069)
at com.pega.pegarules.integration.config.internal.util.WSDLUtils.getWSDLAsString(WSDLUtils.java:373)
at com.pega.pegarules.integration.config.internal.util.WSDLUtils.createWSDL(WSDLUtils.java:360)
at com.pega.pegarules.integration.engine.internal.util.PRServiceUtils.createWSDL(PRServiceUtils.java:594)
at com.pega.pegarules.integration.config.internal.util.WSDLUtils.serveWSDL(WSDLUtils.java:1876)
at com.pega.pegarules.integration.engine.internal.services.soap.SOAPService.invoke(SOAPService.java:276)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:312)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:240)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:277)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:222)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:383)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:271)
at sun.reflect.GeneratedMethodAccessor106.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:349)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:390)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:439)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:99)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:89)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:680)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
***Updated by Moderator: Vidyaranjan | Update thread with SR details***
***Updated by Moderator: Marissa to remove PI***
