Getting error on tomcat while starting PRPC startup 7.12
I just restarted my system and tried to start PEGA Startup 7.12(Personal Edition), however, it is not being up and getting below errors.Show More
I just restarted my system and tried to start PEGA Startup 7.12(Personal Edition), however, it is not being up and getting below errors. For your reference, I am attaching Catalina log here.
Could you please assist on this?
Oct 18, 2016 7:34:01 AM com.pega.pegarules.internal.bootstrap.PRMiniLoader
SEVERE:
Oct 18, 2016 7:34:01 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
19830421:
============ PegaRULES Bootstrap Configuration ============
Date: Tue Oct 18 07:34:01 BST 2016
Java Version: Oracle Corporation 1.7.0_45
Configuration: file:/D:/PegaInstallationDir/PRPCPersonalEdition/tomcat/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: 07-10-05
Database: PostgreSQL 9.4.5
Driver: PostgreSQL Native Driver PostgreSQL 9.2devel JDBC4 (build 1000)
Unable to use given database configuration
Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
SEVERE: Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:377)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:660)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:454)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:506)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4790)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5284)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:618)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:963)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1600)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
SEVERE: Problem during method invocation (contextInitialized)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListener
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:280)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:350)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:455)
Oct 18, 2016 7:34:01 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
Oct 18, 2016 7:34:01 AM org.apache.catalina.session.StandardManager doLoad
SEVERE: ClassNotFoundException while loading persisted sessions: java.lang.ClassNotFoundException: com.pega.pegarules.session.internal.authorization.ContextMapDiagCallback
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1711)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1556)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.apache.catalina.util.CustomObjectInputStream.resolveClass(CustomObjectInputStream.java:76)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.defaultReadFields(Unknown Source)
at java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at org.apache.catalina.session.StandardSession.readObject(StandardSession.java:1595)
at org.apache.catalina.session.StandardSession.readObjectData(StandardSession.java:1060)
at org.apache.catalina.session.StandardManager.doLoad(StandardManager.java:284)
at org.apache.catalina.session.StandardManager.load(StandardManager.java:204)
at org.apache.catalina.session.StandardManager.startInternal(StandardManager.java:491)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5293)
Oct 18, 2016 7:34:01 AM org.apache.catalina.session.StandardManager startInternal
SEVERE: Exception loading sessions from persistent storage
SEVERE: Context [/prweb] startup failed due to previous errors
19830421: prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
19830421: Will load phase 2 bootstrap from Pega-EngineCode:07-10-05
SEVERE:
SEVERE: ============================= Failed to bootstrap PegaRULES =============================
SEVERE:
SEVERE: Could not load the java class 'com/pega/pegarules/internal/bootstrap/phase2/PRBootstrapImpl.class' from the database table 'pr_engineclasses'
SEVERE: This is usually due to an empty 'pr_engineclasses' table, or possibly it does not contain the configured codeset version.
SEVERE: In this run the prbootstrap.properties specified 'pega-enginecode:07-10-05', checking database...
SEVERE:
SEVERE: 'pr_engineclasses' contains a total of 108982 classes, searching for available codesets...
SEVERE:
SEVERE: Codeset |Version
SEVERE: pega-enginecode |07-10-23
SEVERE:
Show Less
