Getting Error in retrieving a class definition in find when doing Property-Set-XML
I am doing Property-Set-XML based on the XSD structure imported into the application. All the properties are set in the XML stream rule based on mapping but in the last step of Property-Set-XML, i see FAIL step and below error :
** Error in retrieving a class definition in find **
Due to this, the Connect-REST step is also not executed. Has anyone seen this issue before ?
Please suggest.
