Anthem, Inc.
Last activity: 23 Sep 2022 10:29 EDT
get the sum of difference in time taken in minutes between pxcreatedatetime and pxsavedatetime
I need to get the sum of time difference taken between pxcreatedatetime and pxsavedatetime for each case in a report to calculate the time taken to process all the cases in a day.
I am able to get the difference in minutes, but getting the sum is giving wrong values. Any suggestions to approach this in a report definition is appreciated.
Hi @SravanthiM2905 ,
You can refer to this thread to check the configuration required to show the sum of values in a report definition.
https://support.pega.com/question/need-show-total-column-report-definition
Let me know if it helps!
Dipti Aggarwal
