Fail error during Single Sign On using built on application
We have a SSO implementation using custom authentication activity. The requestor type is mapped to an unauthenticated access group with PegaRULES:Guest-Maximum as user role. The AG is mapped to an application A whose rule sets have the authentication service and the authentication activity. The authentication activity invokes a connect-http service which is also in rulesets belonging to application A.
Due to some changes, we have created an other application B and added application A as built on to B. Now, we are referring B in the earlier mentioned Unauthenticated AG. We are seeing error during the execution of the connect-http service. I error we see is:
Only authenticated client may start this activity: RULE-OBJ-ACTIVITY RULE-OBJ-REPORT-DEFINITION PXRETRIEVEREPORTDATA #20160614T132614.161 GMT ReqID=HF4B40208D8E3C8E194ABCD195572BF74
com.pega.pegarules.pub.PRRuntimeException: Error: You lack access required to execute RULE-OBJ-ACTIVITY RULE-OBJ-REPORT-DEFINITION PXRETRIEVEREPORTDATA #20160614T132614.161 GMT.
This error does not happen when we directly map application A to the unauthenticated AG. I can understand that PegaRULES:Guest-Maximum does not have access to the class Rule-Obj-Reportdefinition and hence I can see this error. However, Can some one help with this issue to understand why Pega is trying to run a RD when application B is mapped and used as built - on to A.
Attached log for further information
