![](https://accounts.pega.com/sites/default/files/pega-user-image/283/REG-283340.png?source=PUMINIT)
CENTENE Corporation
Last activity: 20 Mar 2018 15:31 EDT
Externalization of prconfig/prlogging xml files is no longer working after upgrade to v7.3.x
We recently upgraded from v7.1.8 to v7.3.1, and have found that the JVM arguments/JAVA_OPTS that have worked in the past to utilize external config files, are no longer working as expected. PEGA logs are no longer being written to the specified locations within prlogging.xml file, and the 'pegatmp' directory defined in prconfig.xml remains empty. How do we get these args/JAVA_OPTS working again, as we had before with v7.1.8?
Example of -D JAVA_OPTS that worked as expected in lower version (v7.1.8):
JAVA_OPTS="$JAVA_OPTS -Dpegarules.logging.configuration=/opt/projects/pega/prlogging.xml"
JAVA_OPTS="$JAVA_OPTS -Dpegarules.config=/opt/projects/pega/prconfig.xml"
***Edited by Moderator Marissa to update categories; add SR Details***
