Extended IH not getting populated using the captureresponse service
Hi Team,
I am trying to extend IH ( IH fact ) to capture some additional properties that we will get in the captureresponse payload as part of Pega NBA-D 8.6
I followed the below steps mentioned:-
Also my PegaNBAM agents application and default ruleset versions are all pointing correctly.
Inspite of the above, i could not load the data to the newly added columns in IH.
But , if i modify the CaptureResponseData Data Transform and add the mapping of the container properties(Int-PegaCDH-Container-Request), it then writes the values into IH.
So wanted to check , if we really need to add the mapping in CaptureResponseData Data Transform? Or am i doing something wrong here.
