Exposed columns does not reflect across all nodes
Greetings. Hope you are doing well! I am on Pega 8.7.0 and deployed a code which has a column exposed on a table to target environment. This exposed column is not reflected across all nodes in a cluster, example, this works on the node from which the deployment has been done but when users try to create cases which are logged onto other node, they get a commit error complaining on this exposed column. A restart of the cluster had resolved the issue but i want to know if there are other options that we should consider without a down-time to the end users?
Bharat
