Exporting to table from a password-protected xlsx
I can open the file file however execution stops after Excel.Open block (at the Excel.ExportToTable block) though message with an exception does not pop up.
@KasiaM40 You might be sure to enable the FilePublisher so that you can see the exception in the RuntimeLog.txt. I imagine there is an exception happening that would get written to the logs that might be helpful to see.
