Export RAP using prpcUtils 7.1.9 taking much longer time
Hi Team,
I am trying to export the zip/jar package using prpcUtils 7.1.9 through jenkins. I am able to export it successfully. However, it is taking around 42 mintues for a 603 KB jar file.
exportRAP:
[echo] PegaRULES Process Commander Export Application Archive complete.
BUILD SUCCESSFUL
Total time: 42 minutes 19 seconds
Exiting with NO Error
I have done some research and found that we can use custom prconfig.xml file
# Use the following properties If you want to use a custom prconfig.xml or prbootstrap.properties file
pegarules.config=
I have used a custom prconfig.xml file and ran the job again and this time it took around 27 minutes.
exportRAP:
BUILD SUCCESSFUL
Total time: 27 minutes 37 seconds
Can anyone help me out on how to improve the performance/ decrease the time frame ? Or any other options which will help to speed up the export process ?
Any help in resolving this issue will be highly appreciated.
Thanks & Regards,
Ram Gopal K
