Exercise System Missing Operators/Applications
I downloaded the exercise system for the LSA 8.3 course. The first exercise in the course which has you log into your VM has you use Admin@Booking password: rules. This account does not exist, nor do the access groups or applications it belongs to.
Is there an updated version of the VM? I downloaded the VM on 1/12 around 9 PM. This is not allowing me to complete the next exercises as it is based on this one.
We are experiencing some issues at the moment.
The text in the "Implementing the case type life-cycles" was supposed to replace the text in the "Initializing the Event Booking Application" exercise,
The "Download solution" solution link unfortunately is not working.
In the 8.3.1 LSA course you primarily analyze the provided solutions.
Loading the first solution then logging in as Admin@Booking will take you to Booking 01.01.01 where case life cycles have yet to be defined.
You could then switch to 01.01.02 to see minimal case life cycles implemented for the Event and Weather cases.
Ultimately you will load the 01.01.03 solution in the "Adding Hotel as a Built-on Application" exercise. The difference will be dramatic.
