Evonsys
Evonsys
Evonsys
Posted: Aug 8, 2019
Last activity: Sep 3, 2019
Last activity: 3 Sep 2019 17:05 EDT
Exercise: debugging using Tracer failing on pyCommit error
This exercise runs Payroll Setup without and then with Tracer on. Without Tracer, everything operates as defined. With tracer I get the following error. The error not only appears on the Calculate exemptions step, but elsewhere in the platform under the same conditions. For instance, I get the error when I try to save pyDefault.
pyCommitError:Unable to execute Query - [set auto_explain.log_min_duration='-1']: code: 0 SQLState: 25P02 Message: Batch entry 0 set auto_explain.log_min_duration='-1' was aborted: ERROR: current transaction is aborted, commands ignored until end of transaction block Call getNextException to see other errors in the batch.
