Error while running static assembler from dev studio.
Getting error even after adding appropriate roles for the class LOG-PEGARULESMOVE
You are not authorized to create, modify, or lock instance LOG-PEGARULESMOVE ASSEMBLEAPP14!20200807T172841.473 GMT
2020-Aug-07 13:28:41 Starting Static Assembly Application RxPFuture Version 01.01.01 2020-Aug-07 13:28:41 Number of rules identified to assemble 64 2020-Aug-07 13:28:47 Exception while Assembling: 2020-Aug-07 13:28:47 Error in assembling the rule You are not authorized to create, modify, or lock instance LOG-PEGARULESMOVE ASSEMBLEAPP14!20200807T172841.473 GMT at com.pega.pegarules.pub.database.AuthorizationException.createCannotModifyException(AuthorizationException.java:261) at com.pega.pegarules.data.internal.access.Saver.checkSecurity(Saver.java:769) at com.pega.pegarules.data.internal.access.Saver.save(Saver.java:658) at com.pega.pegarules.data.internal.access.Saver.save(Saver.java:1843) at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:2842) at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:2833) at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:2824) at com.pega.pegarules.generation.internal.assembly.staticassembly.AssemblyLogHelper.updateLogEntry(AssemblyLogHelper.java:138) at com.pega.pegarules.generation.internal.assembly.FUAHelperImpl.primeAssemblyCache(FUAHelperImpl.java:1474) at com.pega.pegarules.generation.internal.assembly.ApplicationAssembly.assembleApplicationRules(ApplicationAssembly.java:93) at com.pega.pegarules.generation.internal.assembly.ApplicationAssembly.startAssembly(ApplicationAssembly.java:79) at com.pega.pegarules.generation.internal.PRGenProviderImpl.startAppAssember(PRGenProviderImpl.java:974) at com.pega.pegarules.session.internal.mgmt.Executable.startApplicationAssembler(Executable.java:9432) at com.pegarules.generated.activity.ra_action_pzstartassembly_61e345eece7f2c9eefc153faf7e7ebb9.step1_circum0(ra_action_pzstartassembly_61e345eece7f2c9eefc153faf7e7ebb9.java:170) at com.pegarules.generated.activity.ra_action_pzstartassembly_61e345eece7f2c9eefc153faf7e7ebb9.perform(ra_action_pzstartassembly_61e345eece7f2c9eefc153faf7e7ebb9.java:72) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2674) at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivities(ThreadRunner.java:572) at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivities(PRThreadImpl.java:482) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.executeBatchTask(QueueProcessor.java:297) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:362) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1155) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1371) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1114) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:995) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:816) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
