Rabobank
SE
Last activity: 25 Jan 2019 7:20 EST
Error when creating Case via File Listener
While creating case via File listener, getting this below error in logs.
Problem evaluating When condition: The reference .pyDisplay().pyUIActive(1).pyStreamName is not valid. Reason: invalid subscript for non-list property pyUIActive - Error 1
Section 'pyCaseMainInner' execution error on page 'pyWorkPage' of class '{Work Class}'.
com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' - Error 2
Section 'pyCaseMain' execution error on page 'pyWorkPage' of class '{Work Class}'.
java.lang.RuntimeException: Component stack mismatch {"whenId":"663babf22e9b4f6f29932063521a4fcb328c908c_6","pyName":"pxVisible"}!!!!===={"paramName":"EXPANDEDSubSectionpyCaseMainBBB","liveUI":"data-ui-meta=\"{'type':'Layout','subType':'SECTIONINCLUDE','pgRef':'.pySections(3)'}\"","sectionIndex":"3","isSectionIncl":"true","pxWhenIdentifiers":{"pyVisibilityWhenId":"6fbb3c0a05e711f37c4c7929d5f4a672b116ff8d_6"},"pyName":"pxLayoutContainer","pyTemplates":[{"pxReferencedId":"6fbb3c0a05e711f37c4c7929d5f4a672b116ff8d_5","pyName":"pxSection"}]} - Error 3
Section 'Review' execution error on page 'pyWorkPage' of class '{Work Class}'.
java.lang.RuntimeException: Component stack mismatch {"whenId":"663babf22e9b4f6f29932063521a4fcb328c908c_6","pyName":"pxVisible"}!!!!===={"scrollClass":"","centerInspectorData":"data-ui-meta=\"{'type':'Panel','subType':'CENTER'}\"","ariaLabelCenterPanel":"Center Panel","startWrapperDiv":"true","endWrapperDiv":"false","pyName":"pxWorkAreaContent","pyTemplates":[{"pxReferencedId":"417de4788427dbaa6acaa946e63986d886ca7d90_4","pyName":"pxSection"}]} - Error 4
This does not occur when we manually create case or create case by running the Service file.
I even tried to create cases by changing the AG to the one which was defined in the Service Package but not able to reproduce it.
Any insight on this ?
The same errors are coming in our application as well but different scenario. When the case comes to last assignment in the screen flow, the harness is failing and we see similar errors in the logs.
We have upgraded from 7.3 to 8.1.1. Appreciate if anyone has any resolution on this.
Veera
