Deloitte
Last activity: 25 Nov 2017 7:45 EST
Error when adding Controls to Windows Form in Pega Robotics Studio
Hi I just started working with Robotic Studio and doing the course. When I add controls to a Windows Form I get the error 'Could not get reference to OpenSpan.Dynamicmembers.Extentions.IExtentionTypeService'. I added a snip of the error.
I cannot find any information on this error and how to get rid of it.
Can someone please help me?
I am seeing this problem when I create a new, empty project and add a Windows Form as my first item in the project. Then I add a control to the form. Does this behavior happen in every scenario? or is there something specific that you are doing to recreate it?
I was able to get rid of the error by adding an Automation Item to my project.
I've never seen this error before. I suggest that you open an SR with support as it appears you need someone who can look at your machine. If you do open an SR, please post the SR number here for tracking purposes.
The following article will be help you in creating an SR-
My Support Portal explained for Pega Robotic Automation (formerly OpenSpan)
What version of .Net is installed on your machine? Have you always experienced this issue since installing OpenSpan?
Infosys
I'm seeing the same error as well.
Attached are the error and the list of Microsoft's VS related software installed.
This is what i did so far: Uninstall all Microsoft's software from my pc, ran the OpenSpanStudioVS2015Setup as an admin. Installed just what the OpenSpan installer installs.
"OpenSpan.Dynamicmembers.Extentions.IExtentionTypeService" doesnt exists neither anywhere in my system nor in the extracted "OpenSpanStudioVS2015Setup1.cab" file
More Info: When the solution is built
Pega Robotics Output Publisher diagnostic log
Computer: WIN10
Created date: 8/25/2017 9:52:53 AM
MsgType | Timestamp | Thread | State | Category | DesignComponent | Component | Message (Plus Verbose message, if included)
Info | 09:52:58.986 AM | 1 | STA | User Data | | | Application path is not writable: C:\Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015
Info | 09:52:59.002 AM | 1 | STA | User Data | | | PublicAssemblies path: C:\Users\<user>\AppData\Roaming\OpenSpan\PublicAssemblies
Info | 09:52:59.331 AM | 1 | STA | Component Inspector | | | Deserialized 'D:\Documents\Pega Robotics Studio\Projects\CustomersSearching4Stores\CustomersSearching4Stores\Windows Form1.os' in 0.02 seconds
Info | 09:52:59.409 AM | 1 | STA | Project | | | Project 'Main-UI' opened
Info | 09:52:59.508 AM | 1 | STA | Office | | | Attempting to copy office files from C:\Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015\Office2016
Info | 09:52:59.523 AM | 1 | STA | Office | | | Result from office assembly copy from C:\Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015\Office2016: SameOfficeVersion
Info | 09:52:59.523 AM | 1 | STA | Shell | | | State changing from Default to Designing
Info | 09:53:00.677 AM | 1 | STA | Project | | | Project 'Main-UI' error check started
Info | 09:53:00.693 AM | 1 | STA | Project | | | Project 'Main-UI' error check finished
Info | 09:53:00.936 AM | 1 | STA | Designer | | | Loaded designer extension.
Info | 09:53:01.132 AM | 1 | STA | Designer | | | Deserialized 'D:\Documents\Pega Robotics Studio\Projects\CustomersSearching4Stores\CustomersSearching4Stores\Windows Form1.os' in 0.23 seconds
Info | 09:53:01.231 AM | 1 | STA | Shell | Windows Form1 | | Designer created and initialized for 'D:\Documents\Pega Robotics Studio\Projects\CustomersSearching4Stores\CustomersSearching4Stores\Windows Form1.os'
Error | 09:53:05.199 AM | 1 | STA | Exception | | | Could not get reference to OpenSpan.DynamicMembers.Extensions.IExtensionTypeService., Verbose Message: General Information
Diagnostic Info:
Diagnostic.MachineName: WIN10
Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e
Diagnostic.AppDomainName: DefaultDomain
Diagnostic.WindowsIdentity: WIN10\<user>
Diagnostic.ApplicationName: OpenSpan.Studio.Shell
Exception Information
1) Exception Information
Exception Type: OpenSpan.ServiceNotAvailableException
MachineName: "WIN10"
CreatedDateTime: 8/25/2017 9:53:05 AM
AppDomainName: "DefaultDomain"
ThreadIdentityName: "WIN10\<user>"
WindowsIdentityName: "WIN10\<user>"
AdditionalInformation: NameValueCollection with 0 items
Message: "Could not get reference to OpenSpan.DynamicMembers.Extensions.IExtensionTypeService."
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: T GetService[T](System.IServiceProvider, Boolean)
HelpLink: NULL
Source: "OpenSpan"
HResult: -2146232832
StackTrace Information
at OpenSpan.Utils.Extensions.ServiceProviderExtension.GetService[T](IServiceProvider serviceProvider, Boolean throwOnNull)
at OpenSpan.DynamicMembers.Extensions.ExtensionHelper.GetExtensionType(Object instance)
at OpenSpan.DynamicMembers.Extensions.ExtensionHelper.GetMembers(Object instance, MemberTypes memberType)
at OpenSpan.IDE.Tools.ObjectInspector.BuildMemberNodes(Type instanceType, MemberTypes memberType, ArrayList& nodes)
at OpenSpan.IDE.Tools.ObjectInspector.BuildAllMemberTypeNodes(Object instance)
at OpenSpan.IDE.Tools.ObjectInspector.InspectType(Object instance, ComponentIdentity componentId, String subProperty, Type subPropertyType)
DE
Hi, I have exactly the same behavior in 2 different environments.
First env is Windows 10 physical installation.
Second is Windows 7 in parallels on Mac.
Whenever I drag'n'drop any Windows Form objects into a Windows form I see the error.
I have reinstalled, removed old .NET aso, nothing helped.
Andreas
DE
That really does the trick! Although I am getting the same error message when adding the automation item to the project, the error does no longer occur for Windows form objects.
Thanks Vegam. You saved my day ;)
Accenture
Excuse me but, how do I add an automation item? I'm also getting this error and it's super annoying.
Thanks.
DE
Right-click the project in the solution explorer choose "Add", from the sub menu select "New Automation..."
Hope that helps
Andreas
Infosys
Surprisingly, adding an Automation item suppressed the error message.
Which build number are you working with?
DE
I see the issue with Version 14.0.25420.1 (8.0.1053.0). But I tried two different downloads. One is the product that was shipped through the software request and the other one came from the Robotics Architect Training currently available. Both installations behave the same even on different environments and different Windows versions. Could a Microsoft hotfix cause this issue?
Regards Andreas
