An error occured during resolving the report definition - null
Hi All - I am getting "An error occured during resolving the report definition - null" when launching the user portal in v7.1.9. I found the article on PDN(https://community.pega.com/support/support-articles/report-definitions-cause-null-pointer-exceptions) and it seems this issue existed in v7.1.7 and there was a HFix provided which I assume should already be resolved in v7.1.9. But it seems not fixed in v7.1.9. So do I need to create SR to get the corresponding HFix for 7.1.9?
I have a SQL function defined for one of the column in my report definition as well as corresponding repeating grid column to enable the pyID sorting based on Number and not String. Which I believe should be causing this issue.
