Error compiling: com/pegarules/generated/pega_appdefinition_utilities; see class's compile log file.
Greetings. We keep seeing the below compilation errors whenever we restart the JVM and having problems loading the Pega.
2017-11-02 06:35:15,469 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_integrationengine_default; see class's compile log file.
2017-11-02 06:35:15,607 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_procom_default; see class's compile log file.
2017-11-02 06:35:15,727 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_processengine_flowutilities; see class's compile log file.
2017-11-02 06:35:16,027 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_procom_pegaprocomutilities; see class's compile log file.
2017-11-02 06:35:16,182 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_uiengine_uiengine; see class's compile log file.
2017-11-02 06:35:16,351 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_processengine_workutilities; see class's compile log file.
2017-11-02 06:35:20,422 [ vrhpbcp202] [ STANDARD] [ ] (ary.LibraryFunctionUtilityImpl) ERROR - Error compiling: com/pegarules/generated/pega_processengine_casetypefua; see class's compile log file.
I have also looked at the logs from PRGenClasses and i can see the below errors
