erronr hanlng in connect rest
My requirement is On click of attaching button in the back end we are calling connect rest, few fields we set validation
Whenever the fields i.e. the response property is blank. We are getting validation message in the clipboard
But on the portal after clicking on the attach button the validation message should show?
I tried adding a message in DT but it's not working can someone provide inputs.
From where you are running this is it from the case or landing page.
Is the error from the datapage you want to capture, then from the datapage response enable error handling and then set the message on the page where you want to see.
Can you share the screen shot can better understand the issue.
