Tata Consultancy Services
Last activity: 12 Oct 2021 16:28 EDT
Edit Input to allow only numbers and restrict numbers to length 5
I have a requirement to allow only numbers in the integer property with restrict the length upto 5 digits using edit input rule. Is there any OOB pega rule is available for this?
I want to know what is slice in pega edit input rule?
Could you please help me in this
Hi Sridhar,
You can use the edit validate rule "IsInteger" and in the Advance tab of the property rule you can restrict the number of characters in the "Max Length" field.
Vikash
