Dynamic column name in grid
It's possible to reference value from clipboard instead of static label in column's name in grid?
How can we achieve this?
Hi, Sunny_GCS,
It was so obvious that I even didn't try this option...
Thank you, it worked well!)
You should be able to use a field value to link a property, the field value syntax is {.PropertyName}
What version of Pega are you on? I just tried a quick test in one of the UI gallery grid examples. Dragged a Text input control and referenced a clipboard property, it worked out ok for me. In my example, I just used an existing top level clipboard page OperatorID and referenced the pyUserName on that page. It displayed the value at runtime just fine.
-Sunny
