Dropdown is showing as Open instead of "OPen/OPEN/open" values
We need to display the values from a data type field in a dropdown control. The data type has values like open, OPEN, OPen (case-sensitive). We need to show the exact values in the dropdown. We are using a Report Definition as a source to dropdown control.
The issue here is we can see the dropdown values in the UI but it is showing as Open instead of "OPen/OPEN/open" values. We have a similar problem for the "close" value also.
