Capgemini
Capgemini
Capgemini
Posted: Feb 22, 2018
Last activity: Mar 26, 2018
Last activity: 26 Mar 2018 7:02 EDT
Dropdown option with allowed results disappear when "Allowed to update column layout" is unchecked
- Results are limited with choices defined in "Results defined by property"/"Result" field in a decision table.
- When "Allowed to update column layout" is checked, we can see a dropdown with valid options in the Return column
- When "Allowed to update column layout" is unchecked, the dropdown disappears and instead a property selection control is displayed.
The above behavior is observed in both 7.1.9 and 7.3.1
Is there any fix/workaround known as we intend to delegate the decision table with "Allowed to update column layout" unchecked and still would like to have the dropdown of valid options while editing the rule.
Thanks.
