To Do Widget not showing assignments on first step after case is created using create case smart shape
Did anyone have faced synchronization issue on To Do Widget used for Work Queues on Constellation UI using Infinity '23. I have a scenario to create a case from another case (using create case smart shape). The newly created case has the first assignment routed to a work queue and this is being taken care by To Do Widget configured on App Studio to show the assignment on portal. The work queue configuration is fine as the assignments are getting routed to it from 2nd level of that case processing, but it's not showing up the assignment when the case is created on very first stage after create stage where the same work queue is configured to be routed. On the very first stage where the assignment is not shown on To Do Widget, if the case is searched from portal the assignment shows the correct work queue it is assigned but To Do Widget is not reflected with it. Anyone has encountered this issue in Constellation? Is this a known issue?
