  CNO Financial Group Inc
Last activity: 28 Jun 2019 15:04 EDT
Discrepancies between BAE course and quizzes
I've noticed quite a few verbiage discrepancies in the course which could cause a lot of issues on the exam. For example, in optional user actions they are referred in the training module as Optional user actions. On the quiz, they call it a Local Action. Has anyone else noticed this? It is somewhat concerning for me.
What version of the BAE course are you referring to? the 7.3/4 version?
eddie
Yes, 7.3/7.4. I've heard I should perhaps focus on version 8 instead as the exam may be more straightforward and directly related to the online training than version 7. Any thoughts on that?
Focus your certification on the product version you will be using first. The PCBA cert is ~90% the same between 7.3 and 8; things like case lifecycle design, UI design, data modeling, and business reports are universal and timeless, so immune to tectonic shifts from one version to the next. However, that other 10% may cause you grief if you certify on 8 but spend all your time working in 7.3 - or the other way around.
I will post another reply here to help you understand the differences between optional user actions and local actions.
eddie
Just checking if you have the time to post the reply on the differences between optional user actions and local actions?
I read through the lesson and the quiz. Words do seem to be used interchangeably w/o saying that out loud. I'll see if I can get an update.
All optional actions are optional user actions because a user has to make a purposeful choice to take one of the available actions.
Optional (user) actions come in two flavors:
1) a local action - which is always ever just a single assignment, and
2) a process - which can include more than one assignment - and a bunch of other process related steps.
The key data point about a local action is that, while I am actively working an assignment, I can do something else in a single, but different assignment - then come back to the original assignment and finish it. This is the primary reason a local action is sometimes referred to as an optional user action; because it cannot be completed w/o user intervention (action). Not the best choice of words, but that is the connection most folks make.
The key data point about an optional process is that, while I am actively working an assignment, I can kick off an entire separate process - which may contain automated steps such as sending an email, evaluating a decision table, changing from one stage to another, even closing the case. Because these automated steps do not require user intervention, these are commonly referred to as optional processes. An optional process can most certainly be completed w/o user intervention; except for invoking it in the first place of course.
does this help clarify?
eddie
Thanks Eddie, this does help. For an optional process, it doesn't have to be automated though, an optional process could kick off a process that does require a user to actually complete work manually, right?
  Brijesh Vanapalli Dharani Murugan
yep. The optional process can have any available flow shape in it, including assignments; notice the plurality.
eddie
