Disable hyperlink display for MultiSelect / ComboBox values in Constellation
Hi Team,
We are facing an issue with Multiselect / ComboBox fields in Pega Constellation UI.
When a user submits a case with a Multiselect, the selected values display correctly on the entry screen. However, on the Review screen, the values are rendered as hyperlinks instead of plain text.
Is there any configuration or recommended approach to disable the hyperlink behavior for Multiselect values and display them as non-clickable text?
Thank you for your help!
