Birlasoft
Birlasoft
Birlasoft
Posted: Feb 23, 2023
Last activity: Feb 25, 2023
Last activity: 25 Feb 2023 9:56 EST
Different header color for expand and collapse
I need to change the color for the header when it is expand the color should be different and when it is collapsed color should be different.
but I see in the skin of Pega having only one option of header color.
How can we achieve this different header color for expand and collapse?
***Edited by Moderator Marissa to add Capability tags***
@KajalS99 Can you try if you are able to apply a container to it and apply backgroud colour to container(different containers with different background) and then refer container dynamically through a property. When you click on expand./collapse, you will need to run a Data transform to set the container name to the reference property in the container.
