Difference between Indirect Value vs Behavior in PAD
When creating a spectrum model, we can choose between the 'Default' or the 'Recommendation - Indirect Value Prediction' templates. However, in the final model output, the 'Default' template outputs 'Behavior' as the final value and the 'Recommendation - Indirect Value Prediction' template gives 'Indirect Value'.
1) Is there a difference between both these templates?
2) Is there a difference between 'Behavior' and 'Indirect Value'
Ritu
