thryvedigital
Last activity: 1 Aug 2023 14:53 EDT
Deploying two pega application with Two different rule shcema & same data schema in a same database -Pega 8.6.1
Hello All,
It would be helpful to me if you can give some solution or idea on the below requirement.
Requirement:-
How we can deploy the two pega applications with different rule schema & same data schema in the same database?
Example:- We need to deploy the two pega applications called Application A & Application B. Application A will connect to Rule Schema A & Data Schema A and Application B would connect to Rule Schema B & Data Schema A [ Data schema are same] in the Same database.
Ram
