UMKC
Last activity: 4 Apr 2024 16:29 EDT
Declare OnChange rule not visible in references
I created an activity(lets call it A) and the activity is called from a Declare OnChange rule.
When the property in the Declare OnChange rule changes, Declare OnChange rule is executed and the activity A is called as expected.
Now when I open Activity A and click on view references of Activity A, I cannot see the Declare OnChange rule where this activity is called from.
The activity is being executed as expected but for some reason I'm unable to spot the Declare OnChange rule from view references option, is this an expected behavior ?
I'm using the latest cloud community edition
Hi@KevinR17115962
The acitivity should show the referred declare on change rule. Please find the attached image of an OOTB activity.
Maybe it is caused due to caching issue on your environment, try log off login once and see if it appears.
