Declare index not firing on commit
I have this requirement to add an index instance to a database table using an OTA. Main point of this index record is to track the current stage of a work object and some other required values.
Following are the points.
- I have a declare trigger(A) track the work object's current stage.
- So when the stage changes, the trigger(A) will call and execute an activity(B).
- Also I have a declare index rule which is mapped into a page group property & I'm populating the page group property values using a data transform(C) and calling it inside the triggering activity(B).
- In the normal path when a work object is changing through stages, this logic works fine.
- But for some previous work objects which were created before this trigger, I need to run an one time activity and add this index instance manually.
The logic inside my OTA is as following.
- Open the work objects.
- Run the data transform to create and populate the page group property which is linked to the declare index.
- Call commit with error handling on work object.
Result
Result
- In the clipboard, I see the populated page group property inside every work object.
- But when I query the database table, there're no index records for the work objects.
Please correct me if I'm wrong, since this is a declarative rule shouldn't it call whenever I commit my work object with the linked property to execute the trigger? Am I missing something here? Appreciate if anyone could provide an immediate answer.
