Accenture
Accenture
SG
Accenture
Posted: May 31, 2017
Last activity: Jun 23, 2017
Last activity: 23 Jun 2017 9:24 EDT
Declare Expression not working on Data Classes
Please refer above post and can some one confirm Is it resolved in 7.2? I mean will automatic posting is allowed on Data-.? or please provide SR/Hot fix to work for Data- .
As I'm currently using 7.2.2 and if I write declare expression in some data class it is not posting automatically unless explicitly refreshing.
Hi Aditya,
I do not believe this behavior has changed at all. If the value of your properties are not updated and reflected on the clipboard, then your declare expressions will not fire. So in this use case, yes, you would still need to post your values to the server.
