Cognizant
Last activity: 4 May 2016 13:55 EDT
Declare expression does not trigger in production
We had a production issue in PRPC 6.3 SP1 - Declare expression does not trigger in production but working in non-prod.
Also,revalidate and save didn't work in production and non-prod for same declare expression.
Declare expression started working after execution of below steps.
1) Either remove that reference entirely if it is not needed, or re-root your declare-expression to be applied to the subclass of main rule class.
2) Resave the declare expression again.
But,didn't get any satisfactory answer for below questions in SR-A23881. It would be greatly appreciated if anyone provide the answers for below questions.
1) Is there a way to go back and check the old declarative network snapshot to see to identify root cause of failure?
2) Why will the product behave differently in lower and in production for same code base?
3) What is the set of rule apart from this declare expression that we need to look at?
AB
