Ford Motor Company
Last activity: 20 Sep 2018 22:38 EDT
Decision Data Store is not connecting(Showing Joining)
We have websphere with cluster, we have 2 server and 2 JVMs. When we try to enable the one JVm, its showing joining and other one looks Normal.
Did anyone face the same issue and its needs to run on both server?
We are using PegaMarketing 7.31.
Anandh
Hi Anandh,
You meant one of the DDS node, while adding its shows JOINING all the time.
Could you attach the DDS node log to investigate.
Regards
Sibani Saidarsini
Ford Motor Company
Yes, its showing JOINING all time. Here the diagnostics,
*/ <pagedata> <pxObjClass>Embed-Decision-Service-Monitoring-DDS</pxObjClass> <pyWriteFiveMinutesThroughput>0.000000</pyWriteFiveMinutesThroughput> <pyOwnership>?</pyOwnership> <pyWriteLatency75Percentile>——</pyWriteLatency75Percentile> <pyAdvancedDiagnostics>Operation mode from management: JOINING Reachable nodes: [IPS, IPS] Unreachable nodes []</pyAdvancedDiagnostics> <pyReadLatency75Percentile>——</pyReadLatency75Percentile> <pyReadFiveMinutesThroughput>0.000000</pyReadFiveMinutesThroughput> <pyFreeDiskSpace>913 GB</pyFreeDiskSpace> <pyDiskUsage>137 KB</pyDiskUsage> <pyMetrics> <pyReadLatency> <pyFifteenMinuteRate>10.541274388851907</pyFifteenMinuteRate> <py98thPercentile>40942.252760000054</py98thPercentile> <pyMean>2520.295735849056</pyMean> <py95thPercentile>10111.564299999995</py95thPercentile> <py99thPercentile>43508.947</py99thPercentile> <pyMeanRate>4.330197038151125</pyMeanRate> <pyMin>57.709</pyMin> <py75thPercentile>2685.15</py75thPercentile> <pyOneMinuteRate>9.752470795070828</pyOneMinuteRate> <pyRateUnit>SECONDS</pyRateUnit> <py999thPercentile>43508.947</py999thPercentile> <pyStdDev>6244.207581677837</pyStdDev> <pyLatencyUnit>MICROSECONDS</pyLatencyUnit> <pyMax>43508.947</pyMax> <py50thPercentile>849.247</py50thPercentile> <pyEventType>calls</pyEventType> <pyCount>53</pyCount> <pyFiveMinuteRate>10.424797410509147</pyFiveMinuteRate> </pyReadLatency> <pyClientReadLatency> <pyFifteenMinuteRate>0.0</pyFifteenMinuteRate> <py98thPercentile>0.0</py98thPercentile> <pyMean>0.0</pyMean> <py95thPercentile>0.0</py95thPercentile> <py99thPercentile>0.0</py99thPercentile> <pyMeanRate>0.0</pyMeanRate> <pyMin>0.0</pyMin> <py75thPercentile>0.0</py75thPercentile> <pyOneMinuteRate>0.0</pyOneMinuteRate> <pyRateUnit>SECONDS</pyRateUnit> <py999thPercentile>0.0</py999thPercentile> <pyStdDev>0.0</pyStdDev> <pyLatencyUnit>MICROSECONDS</pyLatencyUnit> <pyMax>0.0</pyMax> <py50thPercentile>0.0</py50thPercentile> <pyEventType>calls</pyEventType> <pyCount>0</pyCount> <pyFiveMinuteRate>0.0</pyFiveMinuteRate> </pyClientReadLatency> <pyClientWriteLatency> <pyFifteenMinuteRate>0.0</pyFifteenMinuteRate> <py98thPercentile>0.0</py98thPercentile> <pyMean>0.0</pyMean> <py95thPercentile>0.0</py95thPercentile> <py99thPercentile>0.0</py99thPercentile> <pyMeanRate>0.0</pyMeanRate> <pyMin>0.0</pyMin> <py75thPercentile>0.0</py75thPercentile> <pyOneMinuteRate>0.0</pyOneMinuteRate> <pyRateUnit>SECONDS</pyRateUnit> <py999thPercentile>0.0</py999thPercentile> <pyStdDev>0.0</pyStdDev> <pyLatencyUnit>MICROSECONDS</pyLatencyUnit> <pyMax>0.0</pyMax> <py50thPercentile>0.0</py50thPercentile> <pyEventType>calls</pyEventType> <pyCount>0</pyCount> <pyFiveMinuteRate>0.0</pyFiveMinuteRate> </pyClientWriteLatency> <pyWriteLatency> <pyFifteenMinuteRate>4.390027726408814</pyFifteenMinuteRate> <py98thPercentile>35710.037</py98thPercentile> <pyMean>1744.542742857143</pyMean> <py95thPercentile>16657.292199999898</py95thPercentile> <py99thPercentile>35710.037</py99thPercentile> <pyMeanRate>2.858454740629219</pyMeanRate> <pyMin>41.061</pyMin> <py75thPercentile>305.118</py75thPercentile> <pyOneMinuteRate>4.256079946332782</pyOneMinuteRate> <pyRateUnit>SECONDS</pyRateUnit> <py999thPercentile>35710.037</py999thPercentile> <pyStdDev>6269.6474145340035</pyStdDev> <pyLatencyUnit>MICROSECONDS</pyLatencyUnit> <pyMax>35710.037</pyMax> <py50thPercentile>85.982</py50thPercentile> <pyEventType>calls</pyEventType> <pyCount>35</pyCount> <pyFiveMinuteRate>4.370248616878911</pyFiveMinuteRate> </pyWriteLatency> </pyMetrics>
</pagedata>
Ford Motor Company
i found the solution for this issue, those thread can be closed.
Anandh
Hi @AnandhP2,
It would greatly help our other community members if you could share the resolution.
Thanks!
Accenture Technology Solutions Brasil Ltda
BR
Can you share the resolution?
PNC Bank
I know that it's been a while but I believe I'm facing a similar issue. Please provide the solution you had implemented.
Thanks!
PNC
I am also facing a similar issue. Is there a link for the solution article?
Thanks!
We haven't heard back on the solution yet. Please consider creating a new post for your query.
