Decimal validation causing "Component stack mismatch" error on 'Back' button
On a user form in a flow action, we've got an input field associated with a property of decimal data type. If user enters characters that fail the edit validation (e.g., "123@"), then click the 'Back' button, the screen flow is disrupted with the following error:
_________________________________________________________________________
Section 'Perform' execution error on page 'pyWorkPage' of class 'VAFS-FPS-PAT-Work-Adjustment'. : Component stack mismatch {"pyName":"LayoutGroup"}!!!!===={"scrollClass":"","centerInspectorData":"data-ui-meta=\"{'type':'Panel','subType':'CENTER'}\"","ariaLabelCenterPanel":"Center Panel","startWrapperDiv":"true","endWrapperDiv":"false","pyName":"pxWorkAreaContent","pyTemplates":[{"pxReferencedId":"5d0dbd5a55a4ee2cc3138ecc18aaace81626ea61_6","pyName":"pxSection"}]}
Also, see attached screenshot of error.
This issue seems specific to the decimal validation, because if I change the property to one with integer data type, no such error is encountered.
Thanks a lot to anyone who spends time on this!!!
