Data in Records Blank
Hello!
A data type I made contains several records (that consists of passwords) in a Data type that is sourced by a list and unique data pages. I can verify that the records display in Designer Studio and the portal its used in in one environment. Upon deploying to the next environment, I noticed that the rows for the records are there but the fields are blank. The data page sources are gone too. Does someone know how to fix this?
Here's a quick solution to this issue. What you could do is remove all of the records in the environment(s) the issue occurs then in the environment that the records do display, export it. Then back to the issue environment, import that file.
