Data grid sort column issue
There is data grid on application portal which is generated through data page. Every row has expanded pane which displays some fields and buttons based on conditions. On click of any grid column sorts the rows but expanded panes inside the rows are not appearing as per sorting on grid.
Is there any fix for this issue?
Hello RamKrishna,
Can you share the screenshot of the issue you are facing?
