Cox
Last activity: 8 Aug 2023 10:26 EDT
Data Flow getting invoked automatically
Though the data flow was withdrawn and is not referenced anywhere. But we are seeing in the logs exception related to RuleNotFoundException.
Exception:
ERROR - Unable to find dataflow rule [xxxxx-FW-xxxFW-Data-xxInfo-Kafka.xxxxxxxxxxxxxx]
com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-DECISION-DDF' with the name 'xxxxxxxxxx' that applies to 'xxxx-FW-xxxFW-Data-xxInfo-Kafka'. There were 3 rules with this name in the rulebase, but none matched this request. The 3 rules named 'xxxxxxx' defined in the rulebase are:
2 related to applies-to class 'xxxxx-FW-xxxFW-Data-xxInfo-Kafka', but were defined in rulesets which are seemingly inaccessible to you (check rulesetlist): {xxxFW:01-08-47, xxxFW:01-08-65}.
1 inaccessible because their availability was 'Withdrawn'.
Root Cause:
I identified a pattern , when it was being repeating. It's being repeated whenever there is a commit to the database.
Issue:
Unable to figure out where the data flow is being referenced from or Invoked. After detailed analysis of logs, i could sense it's being triggered from kafka partitions or some background processor.
Kindly help with the necessary technical inputs to fix the issue.
