Customizing Pega-Notification-MobilePush - pySendNotification
I have a requirement to process mobile push notification from a specified application's channel. I mean when a user mentions someone in application A, push notification should be sent through using application's B mobile channel config. I guess I will be able to do it by setting applicationContext and applicationVersion parameters on the step 9.2 of Pega-Notification-MobilePush - pySendNotification activity in 7.4. But there is below error, I can not either save as or edit it. Can you check it ? Should I open an SR ?
Name—
Invalid value specified for pyParametersParamName. Value doesn't adhere to the Validate: pzValidParameterPageName
