Custom Servlet mapping in web.xml not working in Pega 23.1
We have modified web.xml to allow users to login using custom servlet url instead using custom authentication. The login is taking to 404 error or PRBasic screen. The same changes are working on 8.x versions in production today.
https://xxxx.com/poc/login - This is the url we would want the end users to use to login to Pega environment
Attached the web.xml we have modified to make this happen
Note: The same customized web.xml configuration is working today in 8.x environment
