Custom Multi-select not working in Firefox - Event is not defined JS error
Since, window.event.srcElement does not work in Non-IE browser, replaced it with pega.util.Event.getTarget(event) in the Javascript function used for Multi-Select selection. However, in non-IE browser, getting - "ReferenceError: event is not defined" JS error and the control doesnt work. Using 6.3 SP1
Please let me know how the "event" is defined when pega.util.Event.getTarget(event) is used in a custom JS code (Attached is the JS code)..Note: HNB.multiSelectInit is the function used in the control which is defined in the work form
***Edited by Moderator Marissa to update categories; add SR Details***
***Turned off future commenting per Original Poster's Request***
