Creation of Release under Application is causing - 6263 SQLState: S0001 Message: Execution of user code in the .NET Framework is disabled
While performing step - "Configure Applications Environment & Release Details (on Release Management Server)" as part of 7.1 & 7.2 Dev-Ops Accelerator Pack Setup and Configuration Instructions, getting below error while adding Release under Application. On Submit (Finish Assigment step) it Is ending up into "Repair Flow Configuration".
com.pega.pegarules.pub.runtime.IndeterminateConditionalException: There was a problem getting a list: code: 6263 SQLState: S0001 Message: Execution of user code in the .NET Framework is disabled. Enable "clr enabled" configuration option.
Appreciate any help !!
